CLI composable machines management
This is a list of examples of pod-management tasks performed with the MAAS CLI. See MAAS CLI for how to get started with the CLI and Pods for an overview of the subject.
Add a pod
To add a pod:
maas $PROFILE pods create type=$POD_TYPE power_address=$POWER_ADDRESS \
    [tags=$TAG1,$TAG2,...]
Both USERNAME and PASSWORD are optional for the virsh power type. ZONE and TAGS are optional for all pods.
See the API reference for a listing of available power types.
For example, to create an RSD pod:
maas $PROFILE pods create type=rsd power_address=10.3.0.1:8443 \
And to create a KVM host:
maas $PROFILE pods create type=virsh power_address=qemu+ssh://ubuntu@192.168.1.2/system
Create a KVM host with overcommitted resources:
maas $PROFILE pods create type=virsh power_address=qemu+ssh://ubuntu@192.168.1.2/system \
        power_pass=example cpu_over_commit_ratio=0.3 memory_over_commit_ratio=4.6
Create a KVM host that uses a default storage pool:
        power_pass=example default_storage_pool=pool1
Find pod IDs
Here’s a simple way to find a pod’s ID by name using jq:
maas $PROFILE pods read | jq '.[] | select (.name=="MyPod") | .name, .id'
[note][jq][jq] is a command-line JSON processor.
[/note]
Example output:
"MyPod"
1
List resources of all pods
A portion of sample output:
        "id": 93,
        "capabilities": [
            "composable",
            "fixed_local_storage",
            "iscsi_storage"
        "name": "civil-hermit",
List resources of a pod
To list an individual pod’s resources:
maas $PROFILE pod read $POD_ID
Update pod configuration
maas $PROFILE pod update $POD_ID power_address=qemu+ssh://ubuntu@192.168.1.2/system \
List pod connection parameters
To list a pod’s connection parameters:
maas $PROFILE pod parameters $POD_ID
Example output:
    "power_pass": "admin",
    "power_user": "admin"
Compose pod virtual machines
Basic
To compose a basic pod VM:
maas $PROFILE pod compose $POD_ID
    "system_id": "73yxmc",
Set resources
maas $PROFILE pod compose $POD_ID $RESOURCES
Where RESOURCES is a space-separated list from:
**cores=**requested cores
**cpu_speed=**requested minimum cpu speed in MHz
**memory=**requested memory in MB
architecture= See Architecture below
storage= See Storage below
interfaces= See Interfaces below
Architecture
Then, for example:
maas $PROFILE pod compose $POD_ID \
Storage
For example, to compose a machine with the following disks:
  • 32 GB disk from storage pool pool1
  • 64 GB disk from storage pool pool2
Where we want the first to be used as a bootable root partition / and the second to be used as a home directory.
First, create the VM:
maas $PROFILE pod compose $POD_ID "storage=mylabel:32(pool1),mylabel:64(pool2)"
MAAS will create a pod VM with 2 disks, /dev/vda (32 GB) and /dev/vdb (64 GB). After MAAS enlists, commissions and acquires the machine, you can edit the disks before deploying to suit your needs. For example, we’ll set a boot, root and home partition.
We’ll start by deleting the / partition MAAS created because we want a separate /boot partition to demonstrate how this might be done.
maas admin partition delete $POD_ID $DISK1_ID $PARTITION_ID
To find $DISK1_ID and $PARTITION_ID, use maas admin machine read $POD_ID.
maas admin partitions create $POD_ID $DISK1_ID size=512000000 bootable=True
maas admin partitions create $POD_ID $DISK2_ID
To find $DISK2_ID, use maas admin machine read $POD_ID.
maas admin partition format $POD_ID $DISK1_ID $BOOT_PARTITION_ID fstype=ext2
maas admin partition format $POD_ID $DISK1_ID $ROOT_PARTITION_ID fstype=ext4
maas admin partition format $POD_ID $DISK2_ID $HOME_PARTITION_ID fstype=ext4
To find the partition IDs, use maas admin partitions read $POD_ID $DISK1_ID and maas admin partitions read $POD_ID $DISK2_ID
maas admin partition mount $SYSTEM_ID $DISK1_ID $BOOT_PARTITION_ID "mount_point=/boot"
Interfaces
Using the interfaces constraint, you can compose virtual machines with interfaces, allowing the selection of pod NICs.
If you specify an interfaces constraint, MAAS creates a bridge or macvlan attachment to the networks that match the given constraint. MAAS prefers bridge interface attachments when possible, since this typically results in successful communication.
interfaces=eth0:space=maas,eth1:space=storage
Assuming the pod is deployed on a machine or controller with access to the maas and storage spaces, MAAS will create an eth0 interface bound to the maas space and an eth1 interface bound to the storage space.
MAAS automatically converts the ip constraint to a VLAN constraint (for the VLAN where its subnet can be found – e.g. 172.16.99.0/24.) and assigns the IP address to the newly-composed machine upon allocation.
See the MAAS API documentation for a list of all constraint keys.
Compose and allocate a pod VM
In the absence of any nodes in the ‘New’ or ‘Ready’ state, if a pod of sufficient resources is available, MAAS can automatically compose (add), commission, and acquire a pod VM. This is done with the allocate sub-command:
Note that all pod resource parameters are available to the allocate command, so based on the example above, the following works:
maas $PROFILE machines allocate "storage=mylabel1:32(pool1),mylabel2:64(pool2)"
Once commissioned and acquired, the new machine will be ready to deploy.
The labels (i.e. mylabel1, mylabel2) in this case can be used to associate device IDs in the information MAAS dumps about the newly created VM. Try piping the output to: jq '.constraints_by_type'.
List machine parameters
MAAS VM parameters, including their resources, are listed just like any other machine:
Libvirt storage pools
Composing VMs with storage pool constraints
See Compose pod virtual machines.
Usage
Retrieve pod storage pool information with the following command:
Example:
    "used": {
        "cores": 50,
        "memory": 31744,
        "local_storage": 63110426112
    "name": "more-toad",
    "id": 5,
    "available": {
        "cores": 5,
        "memory": 4096,
        "local_storage": 153199988295
    "architectures": [],
    "cpu_over_commit_ratio": 1.0,
    "storage_pools": [
            "id": "pool_id-zvPk9C",
            "name": "name-m0M4ZR",
            "type": "lvm",
            "path": "/var/lib/name-m0M4ZR",
            "total": 47222731890,
            "used": 17226931712,
            "available": 29995800178,
            "default": true
            "id": "pool_id-qF87Ps",
            "name": "name-ZMaIta",
            "type": "lvm",
            "path": "/var/lib/name-ZMaIta",
            "total": 98566956569,
            "used": 15466229760,
            "available": 83100726809,
            "default": false
            "id": "pool_id-a6lyw5",
            "name": "name-RmDPfs",
            "type": "lvm",
            "path": "/var/lib/name-RmDPfs",
            "total": 70520725948,
            "used": 30417264640,
            "available": 40103461308,
            "default": false
    "total": {
        "cores": 55,
        "memory": 35840,
        "local_storage": 216310414407
    "tags": [],
    "type": "virsh",
    "pool": {
        "name": "default",
        "id": 0,
    "zone": {
        "name": "default",
        "description": "",
        "id": 1,
    "capabilities": [
        "dynamic_local_storage",
        "composable"
    "host": {
        "system_id": null,
        "__incomplete__": true
    "default_macvlan_mode": null,
    "resource_uri": "/MAAS/api/2.0/pods/5/"
Delete a pod VM
After a machine is deleted, the machine’s resources will be available for other VMs.
Delete a pod
maas $PROFILE pod delete $POD_ID
Deleting a pod will automatically delete all machines belonging to that pod.
Last updated a month ago. Help improve this document in the forum.
