Machine and device management
Kick-start your MAAS machine deployment
Ready to deploy? With your network configured and images downloaded, you’re set to begin the machine deployment journey with MAAS. Here’s your roadmap:
Make machines available
Start by making your machines accessible to MAAS. You can discover them on your network or manually add them, specifying their power and network configurations. Once they’re available, the customisation stage begins.
Learn how to make machines available
Tailor your machines
Next up is customising your hardware and software. Increase RAM, expand storage, install specific packages or tweak network settings—you call the shots. With MAAS, align your machines with your organisational needs with ease.
Dig into machine customisation
Deploy and scale
After tweaking to your heart’s content, it’s deployment time. Whether you’re setting up web servers, crunching data, or any other mission-critical task, MAAS is your go-to for a swift deployment. Plus, scaling your infrastructure becomes a walk in the park.
Discover deployment tips
Deploying machines with MAAS isn’t just efficient — it gives you the freedom to build your infrastructure exactly the way you want. But why just read about it? Dive in and start deploying your machines today.
Last updated a month ago.
