Using packer, you can build custom, MAAS-deployable images for the following operating systems:
- RHEL 7
- RHEL 8
- CentOS 7
- Oracle Linux 8
- Oracle Linux 9
- VMware ESXi
You can also build deployment Windows images.
Build Linux images
Verify requirements
You need a machine running Ubuntu 18.04+ or 22.04+ with the ability to run KVM virtual machines. Ensure the following components are available:
OS | Additional Requirements |
RHEL 7 | MAAS 2.3+, Curtin 18.1-59+, RHEL 7 DVD ISO |
RHEL 8 | MAAS 2.3+, Curtin 18.1-59+, RHEL 8 DVD ISO |
CentOS 7 | MAAS 2.3+, Curtin 18.1-59+ |
Oracle Linux 8 | MAAS 3.5+, Curtin 23.1+, libnbd-bin, nbdkit, fuse2fs, Oracle Linux 8 DVD ISO |
Oracle Linux 9 | MAAS 3.5+, Curtin 23.1+, libnbd-bin, nbdkit, fuse2fs, Oracle Linux 9 DVD ISO |
VMware ESXi | MAAS 2.5+, qemu-kvm, qemu-utils, VMware ESXi ISO |
Gather components
Collect packer, its dependencies and templates, and a suitable ISO file before starting.
Install Packer
Packer is the tool of choice for building custom MAAS images.
For Ubuntu 18.04+
sudo apt install packer
For Ubuntu 22.04+ (Required for Oracle Linux 8/9)
curl -fsSL https://apt.releases.hashicorp.com/gpg | sudo apt-key add -
sudo apt-add-repository "deb [arch=amd64] https://apt.releases.hashicorp.com $(lsb_release -cs) main"
sudo apt-get update && sudo apt-get install packer
Install dependencies
Install dependencies required for image building:
sudo apt install qemu-utils
For Oracle Linux 8/9 and VMware ESXi, install additional dependencies:
sudo apt install libnbd-bin nbdkit fuse2fs qemu-utils
For VMware ESXi, install Python pip:
sudo apt install pip
Get Packer templates
Clone the Packer templates repository:
git clone https://github.com/canonical/packer-maas.git
Download ISO files
Download the appropriate ISO for your desired OS version and place it in the corresponding subdirectory:
OS | ISO Location | Subdirectory |
RHEL 7 | RHEL 7 DVD ISO | rhel7 |
RHEL 8 | RHEL 8 DVD ISO | rhel8 |
CentOS 7 | Downloaded via template | centos7 |
Oracle Linux 8 | Oracle Linux 8 DVD ISO | ol8 |
Oracle Linux 9 | Oracle Linux 9 DVD ISO | ol9 |
VMware ESXi | VMware ESXi ISO | vmware-esxi |
Customize the image
Modify the Kickstart file to customize the deployment image:
OS | Kickstart File |
RHEL 7 | http/rhel7.ks |
RHEL 8 | http/rhel8.ks |
CentOS 7 | http/centos7.ks |
Oracle Linux 8 | http/ol8.ks |
Oracle Linux 9 | http/ol9.ks |
VMware ESXi | packer-maas/vmware-esxi/KS.CFG |
Refer to the respective Kickstart documentation for detailed customization options.
Configure a build proxy (optional)
To use a proxy during the build process:
Set the HTTP proxy:
export HTTP_PROXY=http://your-proxy-server:port
Modify Kickstart Files:
Add
--proxy=$HTTP_PROXY
to lines starting withurl
orrepo
For Oracle Linux 8/9, set the KS_PROXY
variable:
export KS_PROXY=$HTTP_PROXY
Build the image
Using the makefile
Run the following command in the appropriate subdirectory (rhel7
, rhel8
, centos7
, ol8
, ol9
, vmware-esxi
make ISO=/PATH/TO/your-iso-file.iso
Manually, Using Packer
Alternatively, manually run Packer:
For RHEL 7/8:
sudo PACKER_LOG=1 packer build -var 'iso_path=/PATH/TO/your-iso-file.iso' rhel7.json # or rhel8.json
For CentOS 7:
sudo PACKER_LOG=1 packer build centos7.json
For Oracle Linux 8/9:
packer init .
PACKER_LOG=1 packer build .
For VMware ESXi:
sudo PACKER_LOG=1 packer build -var 'vmware_esxi_iso_path=/PATH/TO/your-esxi-iso-file.iso' vmware-esxi.json
Note: Packer runs in headless mode by default. To view the installation output, connect via VNC or set headless
to false
Upload the image to MAAS
Commands for each OS
OS | Upload Command |
RHEL 7 | maas $PROFILE boot-resources create name='rhel/7-custom' title='RHEL 7 Custom' ... |
RHEL 8 | maas $PROFILE boot-resources create name='rhel/8-custom' title='RHEL 8 Custom' ... |
CentOS 7 | maas $PROFILE boot-resources create name='centos/7-custom' title='CentOS 7 Custom' ... |
Oracle Linux 8 | maas $PROFILE boot-resources create name='ol/8.8' title='Oracle Linux 8.8' ... |
Oracle Linux 9 | maas $PROFILE boot-resources create name='ol/9.2' title='Oracle Linux 9.2' ... |
VMware ESXi | maas $PROFILE boot-resources create name='esxi/6.7' title='VMware ESXi 6.7' ... |
Verify and log in
Deploy the image and log in to verify customizations:
OS | Default Username |
RHEL 7/8 | cloud-user |
CentOS 7 | centos |
Oracle Linux 8/9 | cloud-user |
VMware ESXi | root |
Build Windows images
Since Windows is a proprietary operating system, MAAS can’t download these images. You need to manually generate images to use with MAAS by using Windows ISO images. On the upside, the end result will be much simpler, since there are CLI and WebUI tools to upload a Windows image – which helps automate the process.
Verify prerequisites
To build the image:
- A machine running Ubuntu 18.04+ with the ability to run KVM virtual machines.
- qemu-utils, libnbd-bin, nbdkit and fuse2fs
- qemu-system
- ovmf
- cloud-image-utils
- Packer, v1.7.0 or newer
- A copy of the packer-maas git repository:
Note that Ubuntu 22.04+ is required to build Windows 11 images due to swtpm
(Software TPM) package requirements.
Supported Microsoft Windows versions
This process has been build and deployment tested with the following versions of Microsoft Windows:
- Windows Server 2025
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
- Windows 10 PRO+
- Windows 11 PRO+
To deploy the image:
Gather components
Collect an ISO image and a template before trying to build a Windows image.
Get the windows.pkr.hcl Template
This template builds a dd.tgz MAAS image from an official Microsoft Windows ISO/VHDX.
This process also installs the latest VirtIO drivers as well as Cloudbase-init.
Obtain Microsoft Windows ISO images
You can obtains Microsoft Windows Evaluation ISO/VHDX images from the following links:
- Windows 10 Enterprise
- Windows 11 Enterprise
Build the image
The build the image you give the template a script which has all the customization:
sudo make windows ISO=<path-to-iso> VERSION=<windows-version>
Example:
sudo make ISO=/mnt/iso/Windows_Server_2025_SERVER_EVAL_x64FRE_en-us.iso VERSION=2025
Adjust makefile parameters
EDIT
The edition of a targeted ISO image. It defaults to PRO for Microsoft Windows 10/11 and SERVERSTANDARD for Microsoft Windows Servers. Many Microsoft Windows Server ISO images do contain multiple editions and this parameter is useful to build a particular edition such as Standard or Datacenter etc.
HEADLESS
Whether VNC viewer should not be launched. Default is set to false. This is useful when building images on machines that do not have graphical libraries such as SDL/GTK installed. Headless mode does include an open VNC port to monitor the build process if needed.
ISO
Path to Microsoft Windows ISO image used to build the MAAS image.
PACKER_LOG
Enable (1) or Disable (0) verbose packer logs. The default value is set to 0.
PKEY
User supplied Microsoft Windows Product Key. When using KMS, you can obtain the activation keys from the link below:
Please note that PKEY is an optional parameter but it might be required during the build time depending on the type of ISO being used. Evaluation series ISO images usually do not require a product key to proceed, however this is not true with Enterprise and Retail ISO images.
TIMEOUT
Defaults to 1h. Supports variables in h (hour) and m (Minutes).
VHDX
Path to Microsoft Windows VHDX image used to build the image.
VERSION
Specify the Microsoft Windows Version. Example inputs include: 2025, 2022, 2019, 2016, 10 and 11. Currently defaults to 2022.
Upload Windows images to MAAS
Use MAAS CLI to upload the image:
maas admin boot-resources create \
name='windows/windows-server' \
title='Windows Server' \
filetype='ddtgz' \
content@=windows-server-amd64-root-dd.gz
Last updated a month ago.
