How to get MAAS up and running
MAAS can be installed from snap or Debian packages, and configured for a Proof-of-Concept (POC) or a production environment.
Install MAAS (snap or packages)
Snap is the preferred method for installing MAAS. It offers simple installation & updates, strong isolation and security, and predictable file paths. To install MAAS using snap:
sudo snap install --channel=$VERSION maas
Replace $VERSION with the desired MAAS version.
MAAS can also be installed using the more traditional Debian package:
sudo apt-add-repository ppa:maas/<version>
sudo apt update
sudo apt-get -y install maas
Post-install setup (POC)
The MAAS snap can use a POC configuration with the maas-test-db snap. Enter maas init --help and follow the instructions to set up this configuration.
Post-install setup (production)
Setting up MAAS for production is a little more involved than a POC, but not particularly difficult to accomplish using the following steps:
  1. Disable conflicting NTP:
    sudo systemctl disable --now systemd-timesyncd
  2. Configure PostgreSQL for production:
    sudo -i -u postgres psql -c "CREATE USER \"$DBUSER\" WITH ENCRYPTED PASSWORD '$DBPASS'"
    sudo -i -u postgres createdb -O "$DBUSER" "$DBNAME"
  3. Edit /etc/postgresql/14/main/pg_hba.conf, adding a line for the newly created database:
  4. Initialize MAAS with the database:
    sudo maas init region+rack --database-uri "postgres://$DBUSER:$DBPASS@$HOSTNAME/$DBNAME"
  5. Create an admin user:
    sudo maas create admin --username=$PROFILE --email=$EMAIL_ADDRESS
Configuring and starting MAAS
Once MAAS is up and running successfully, there are a few additional steps to fully enable it.
Checking MAAS status
To check the status of MAAS services, use:
sudo maas status
Output example:
bind9        RUNNING   pid 7999, uptime 0:09:17
dhcpd        STOPPED   Not started
postgresql   RUNNING   pid 8001, uptime 0:09:17
MAAS UI setup
You can set up MAAS using the Web UI:
  1. Access the UI:
    http://$API_HOST:5240/MAAS
    Log in with the credentials created during installation.
  2. DNS forwarder: Set to a suitable value (e.g., 8.8.8.8).
  3. Image import: Select at least one Ubuntu LTS image.
  4. SSH key import: Choose between Launchpad, GitHub, or upload a key from .ssh/id_rsa.pub.
MAAS CLI setup
You can also set up MAAS with the CLI:
  1. Login:
    maas login $PROFILE $MAAS_URL $(cat api-key-file)
  2. Configure DNS:
  3. Add an SSH key:
Enabling DHCP
DHCP must be enabled before MAAS can commission and deploy machines.
UI
Subnets > VLAN > Configure DHCP > Select options > Save and apply changes
CLI
  1. Enable DHCP:
    maas $PROFILE vlan update $FABRIC_ID untagged dhcp_on=True \
  2. Set the default gateway:
Notes on upgrading MAAS
The following general notes apply to an upgrade:
  • Review PostgreSQL Requirements: MAAS 3.5 and later require PostgreSQL 14. Upgrade instructions here.
  • Upgrade Ubuntu if needed: Ensure you’re running Ubuntu 22.04 (Jammy) before upgrading MAAS.
  • Backup your data: Always create a backup before upgrading.
  • Multi-node setups: Upgrade rack nodes first, then region nodes.
Upgrade to MAAS 3.6
Upgrade Snap (region + rack)
sudo snap refresh maas --channel=3.6/stable
Upgrade package (PPA-based installations)
sudo apt-add-repository ppa:maas/3.6
sudo apt update && sudo apt upgrade maas
Upgrade to MAAS 3.5
sudo snap refresh maas --channel=3.5/stable
sudo apt-add-repository ppa:maas/3.5
Upgrade packages from MAAS versions 2.9-3.3
  1. Upgrade PostgreSQL: If running PostgreSQL 12, upgrade to 14.
  2. Ensure Ubuntu 22.04 (Jammy):
    lsb_release -a
    If on Ubuntu 20.04, upgrade:
  3. Add PPA and Upgrade:
  4. Verify Installation:
    maas --version
Upgrade packages from MAAS 2.8 or earlier
  1. Backup your system completely.
  2. Ensure Ubuntu 22.04 (see steps above).
  4. If the upgrade fails, restore from backup and consider a fresh installation.
Upgrade to MAAS 3.4
Upgrade snap
sudo snap refresh maas --channel=3.4/stable
Upgrade package
sudo apt-add-repository ppa:maas/3.4
  • Follow the same Ubuntu and PostgreSQL upgrade steps as above.
Upgrade to MAAS 3.3
Upgrade snap
sudo snap refresh maas --channel=3.3/stable
Upgrade packages
sudo apt-add-repository ppa:maas/3.3
  • PostgreSQL 12 is deprecated in MAAS 3.3 and unsupported in 3.5. Upgrade to PostgreSQL 14 before proceeding.
Additional notes
Avoiding NTP conflicts
If you experience time synchronization issues:
BMC migration issue (MAAS 3.3+)
Ensure unique BMC IP/username/password combinations before upgrading to avoid migration failures.
Verification steps
After upgrading, confirm MAAS is running correctly:
lsb_release -a  # Ensure Ubuntu version is correct
maas --version  # Verify MAAS version
Last updated 19 days ago.
