MAAS provides pre-configured networks for convenience and efficiency. Reconfigure these networks to suit your environment.
Manage interfaces
MAAS gives you detailed control over network interfaces for each machine — including physical NICs, VLANs, bonds, and bridges. These interfaces form the backbone of your deployment topology. Learn how to create, view, and manage them using the MAAS UI and CLI.
Create an interface
Interfaces define how a machine connects to your network. You can create physical, VLAN, bond, or bridge interfaces — each with its own use case. Begin with the most basic type: the physical interface.
Create a physical interface
A physical interface represents a hardware NIC on the machine. MAAS usually detects these automatically during commissioning. You only need to create one if you are:
- manually re-creating the interface layout
- automating machine configuration post-commissioning
- scripting complex interface setups
If the machine is already deployed, you won’t be able to modify or add physical interfaces. Bring it to a “Ready” or “Broken” state first.
CLI
maas $PROFILE interfaces create-physical $SYSTEM_ID (key=value)....
Use key-value pairs to set interface properties like:
name=eth0
– Logical name of the interfacemac_address=00:16:3e:01:2a:3b
– Required if not auto-detectedenabled=true
– Whether the interface is active
Consult the CLI reference for details on parameters and usage.
Create a VLAN interface
You will need VLAN separation for many different purposes:
- Assigning a machine to a specific broadcast domain
- Implementing multi-tenancy or network isolation
- Setting up PXE-booting on a specific VLAN
In MAAS, a VLAN is a virtual interface associated with:
- a parent (usually a physical NIC)
- a VLAN ID (typically between 1 and 4094)
- a fabric (the logical layer in MAAS that manages network topology)
You can create a VLAN interface with a command of the form:
maas $PROFILE interfaces create-vlan $SYSTEM_ID key=value...
This command has two required keys and several optional key-value pairs.
Key | Description |
vlan |
ID of the VLAN in MAAS to assign this interface to |
parent |
ID of the parent interface (usually a physical NIC) |
name |
(Optional) name of the new interface |
mac_address |
(Optional) MAC address if you’re overriding the default |
tags |
(Optional) for internal use or automation |
To find vlan
and parent
IDs from the MAAS CLI:
maas $PROFILE vlans read $FABRIC_ID
Note that you cannot assign a VLAN directly to a physical interface, though once created, this interface can then be bonded, bridged, or assigned IPs just like a physical NIC.
Consult the CLI help page for more details.
Some common mistakes often plague users when creating a VLAN interface:
- Wrong parent ID: Must be a physical interface.
- Deployed machine: Machine must be in “Ready” or “Broken” state.
- Missing VLAN object: The VLAN must exist in MAAS first — you don’t create it here, you are just creating the interface.
- Fabric mismatch: Parent interface and VLAN must belong to the same fabric.
If you’re planning to use DHCP on this VLAN interface, ensure the VLAN is configured correctly in MAAS and the DHCP relay is present.
Bond two interfaces
Bonding is used to group two or more physical interfaces into a single logical interface. You can bond two interfaces for any machine in the “Ready” or “Broken” state (this will not work for deployed machines). This can:
- Provide failover if one NIC fails
- Enable link aggregation (if supported)
Bonding creates interface redundancy and increased throughput on servers with multiple NICs. Avoid bonding if:
- You are using Wi-Fi or virtual NICs
- You do not control the network switch (and cannot configure LACP)
Learn more about bonds, if needed.
How to create a bond
UI:
Machines > (Select machine) > Network > (Select 2 physical interface) > Create bond > (Configure details) > Save interface
CLI:
maas $PROFILE interfaces create-bond $SYSTEM_ID name=$BOND_NAME parents=$IFACE1_ID,$IFACE2_ID <optional parameters>
Note that parents
refer to the IDs of the physical interfaces you want to bond.
Every bond must have a mode, though bonding_mode
is optional in this command. For MAAS, the default bonding mode is balance_rr
, which transmits packets sequentially from the first available slave through the last. This mode is chosen as default because it provides load balancing and fault tolerance.
Refer to the interface CLI reference page for detailed instruction on how to use the CLI command and other bonding mode choices.
Troubleshooting bond creation
Symptom | Likely cause |
Bond not created | One or more interfaces not in the correct state |
No traffic | Switch does not support bond mode |
UI grayed out | Machine not in “Ready” or “Broken” state |
Create a bridge
Bridge interfaces come in handy in when you’re:
- provisioning virtual machines and need them to reach the outside network
- want multiple interfaces to behave like a single network interface
- using KVM, LXD, or libvirt and they require a bridge
- attaching multiple NICs with routes, but without bonding
A bridge interface is a virtual network switch that connects one or more physical or VLAN interfaces together. It can also be used to:
- Allow VMs or containers to share a physical NIC
- Support PXE boot with a bridged external connection
- Route between subnets or bonding multiple interfaces under one IP
Bridging is often confused with bonding. Bonding is about failover or speed; bridging is about routing traffic through multiple interfaces.
To create a bridge interface:
UI
Machines > (Select machine) > Network > (Select interface) > Create bridge > (Configure details) > Save interface
CLI
maas $PROFILE interfaces create-bridge $SYSTEM_ID name=br0 parent=$INTERFACE_ID
Then link it to a subnet:
maas $PROFILE interface link-subnet $SYSTEM_ID $BRIDGE_ID subnet=$SUBNET_ID mode=STATIC ip_address=10.0.0.101
If you need to get the parent ID to create the bridge:
CLI+jq
You can also employ the jq
tool to make the CLI commands a little easier to use:
Required keys (CLI)
Key | Meaning |
name |
Logical name of the bridge (e.g. br0 ) |
parent |
ID of a physical interface to bridge (can add more later) |
Common issues
- This command only works in “Ready” or “Broken” states. No interface changes are allowed on deployed machines.
- The parent interface must not already be part of a bond or another bridge.
- The subnet must be managed by MAAS if you’re assigning static IPs.
- You need the correct subnet ID, which may require filtering by CIDR and
managed=true
You can bridge more than one interface, but only one at creation; add more with the update
subcommand. MAAS does not manage /etc/netplan
directly — so if you bypass MAAS or work post-deploy, remember that netplan configs matter.
Create a bridge with netplan
If you need to create a bridge after deployment – or for bare-metal tweaking – you will need to create it outside MAAS with netplan. For example, this is what you might add to /etc/netplan/50-cloud-init.yaml
network:
version: 2
bridges:
br0:
interfaces:
- enp1s0
addresses:
- 10.0.0.101/24
gateway4: 10.0.0.1
Apply this configuration with:
sudo netplan apply
View and maintain interfaces
Once created, MAAS interfaces can be listed, reviewed, updated, or deleted. The machine must be in the correct state (Ready
or Broken
) to allow most changes. Deployed machines can only be updated in limited ways (e.g., changing MAC addresses for replacement).
See the CLI reference for more details.
List existing interfaces
Use the MAAS UI or CLI to list all interfaces for a specific machine.
UI
CLI
View a specific interface
Use this to inspect one interface on a particular machine.
UI
CLI
maas $PROFILE interface read $SYSTEM_ID $INTERFACE_ID
Update an interface
Update interface parameters — but only if the machine is in Ready
or Broken
state. If the machine is Deployed
, you can update only:
name
mac_address
This allows field-replacement of broken NICs without full re-commissioning.
CLI
maas $PROFILE interface update $SYSTEM_ID $INTERFACE_ID (key=value)...
Use the appropriate parameter set for the interface type (physical, bridge, bond, VLAN, etc.).
See the CLI subcommand reference for key options.
Delete an interface
Remove an interface that is no longer needed. This is typically used when rolling back a misconfiguration or cleaning up testing setups.
CLI
maas $PROFILE interface delete $SYSTEM_ID $INTERFACE_ID
Manage routes and links
Routing and subnet linking are crucial for machine connectivity. MAAS allows interfaces to be connected, disconnected, or routed with custom logic — via both UI and CLI.
This section shows how to disconnect interfaces, link or unlink them to subnets, assign gateways, and add static routes. It also explains how to set up loopback interfaces.
Disconnect an interface
You can disconnect a given interface from its current network configuration. This action:
- Unlinks any connected subnets
- Removes assigned IP addresses
- Detaches from any associated VLAN
This action is only available if the machine is in a Ready
or Broken
state.
CLI
maas $PROFILE interface disconnect $SYSTEM_ID $INTERFACE_ID
Link an interface to a subnet
You can connect an interface to a known subnet. This enables traffic routing and IP assignment. The subnet must exist and be discoverable by MAAS.
CLI
maas $PROFILE interface link-subnet $SYSTEM_ID $INTERFACE_ID mode=<mode> subnet=<SUBNET_ID> [ip_address=<STATIC_IP>]
mode
is usuallySTATIC
orAUTO
ip_address
is optional unless usingSTATIC
mode- You can link to managed or unmanaged subnets
See Link and interface to a subnet in the CLI reference for full options.
Unlink an interface from a subnet
Use this command to remove an interface connection to a subnet without deleting the interface itself.
CLI
maas $PROFILE interface unlink-subnet $SYSTEM_ID $INTERFACE_ID
Set the default gateway
You can update the gateway for a specific subnet. This is a subnet-level setting that affects routing behavior for all devices on that subnet.
CLI
Add a static route
Route specific traffic between source and destination subnets through a defined gateway. Useful for custom networking setups or multi-NIC systems.
UI
Networking > Subnets > (Select subnet) > Add static route > Fill fields > Save
CLI
maas $PROFILE static-routes create source=$SOURCE_SUBNET destination=$DEST_SUBNET gateway_ip=$GATEWAY_IP
Configure a loopback interface
Loopback interfaces can be added after commissioning, using a placeholder MAC address (00:00:00:00:00:00
). This allows MAAS to recognize it as an intentional loopback, not a misconfigured NIC.
To automate loopback setup, use cloud-init
Tag interfaces
MAAS allows you to apply tags to network interfaces, which can be used for filtering, grouping, automation, or custom selection (e.g., during deployments or scripting).
Add a tag to an interface
Use tags to classify interfaces — e.g., "uplink"
, "PXE"
, "isolated"
, etc.
CLI
maas $PROFILE interface add-tag $SYSTEM_ID $INTERFACE_ID tag="my-tag"
- You can apply multiple tags to an interface.
- Tags are case-sensitive.
- Useful in complex environments where roles need to be defined or discovered programmatically.
Remove a tag from an interface
Remove any tag that is no longer needed.
CLI
maas $PROFILE interface remove-tag $SYSTEM_ID $INTERFACE_ID tag="my-tag"
To view existing tags on an interface, use:
CLI
Manage dual NICs
Some deployments require dual NIC configurations — for example, separating public internet traffic from private internal communication. MAAS supports this setup via UI, CLI, or external tools like Netplan.
Set up dual NICs with MAAS
Assign different roles to each NIC:
- NIC 1 (private subnet): Internal network, typically DHCP (
e.g. 192.168.10.0/24
) - NIC 2 (public access): External internet, DHCP or static (
e.g. 192.168.1.0/24
You can configure both NICs through the MAAS UI or CLI by setting interface modes and linking subnets.
Set up dual NICs with Netplan
You can bypass MAAS for some configs by editing /etc/netplan/50-cloud-init.yaml
network:
version: 2
ethernets:
ens18:
addresses:
- 192.168.10.5/24
gateway4: 192.168.10.1
ens19:
addresses:
- 192.168.1.10/24
gateway4: 192.168.1.1
nameservers:
addresses:
- 8.8.8.8
- 8.8.4.4
Apply the configuration to make it effective:
sudo netplan apply
Manage network discovery
MAAS can automatically detect devices on your network, including those it doesn’t manage — like switches, routers, IoT.
Use network discovery to:
- Map live devices in connected subnets
- Track rogue IPs or MACs
- Audit networks for new arrivals
Basic discovery setup
Enable discovery
Turn discovery on to allow MAAS to detect devices on active subnets.
UI
Networking > Network discovery > Configuration > Enabled
CLI
maas $PROFILE maas set-config name=network_discovery value="enabled"
Disable discovery
Stop automatic scanning if you are done, or want manual control.
UI
Networking > Network discovery > Configuration > Disabled
CLI
maas $PROFILE maas set-config name=network_discovery value="disabled"
Set discovery scan interval
Control how often MAAS scans for devices.
UI
Networking > Network discovery > Configuration > Active subnet mapping interval
CLI
maas $PROFILE maas set-config name=active_discovery_interval value=<seconds>
Clear all discovered devices
Start fresh by removing all discoveries to date.
UI
Networking > Network discovery > Clear all discoveries
CLI
maas $PROFILE discoveries clear all=true
Scan specific subnets
Focus your scans to pinpoint specific servers.
UI
Networking > Network discovery > Configuration > Subnet mapping > [CIDR selections]
CLI
maas $PROFILE discoveries scan cidr=10.0.0.0/24
Fine-tune discovery (CLI only)
Use these commands for specific discovery needs.
Force a re-scan
Overwrite cached data and rescan everything.
maas $PROFILE discoveries scan force=true
Use ping instead of nmap
This is useful if nmap
is blocked or too aggressive for your network bandwidth.
maas $PROFILE discoveries scan always_use_ping=true
Slow the scan down
Limiting bandwidth may be helpful on flaky networks.
maas $PROFILE discoveries scan slow=true
Control thread count
Reduce load or speed things up.
maas $PROFILE discoveries scan thread=4
Filter discovered devices
MAAS can filter results for deeper inspection.
- By unknown IP:
maas $PROFILE discoveries by-unknown-ip
- By unknown MAC:
maas $PROFILE discoveries by-unknown-mac
- By both:
maas $PROFILE discoveries by-unknown-mac-and-ip
Clear discoveries (selective)
Delete specific findings that are not currently helpful.
- By IP and MAC
maas $PROFILE discoveries clear-by-mac-and-ip ip=10.0.0.9 mac=00:11:22:33:44:55
- Delete neighbors
maas $PROFILE discoveries clear neighbours=true
- Delete mDNS
maas $PROFILE discoveries clear mdns=true
Manage subnets
The following instructions are based on MAAS 3.4. For earlier versions, the UI element names may differ.*
Examine subnets
UI
CLI
- List subnets:
- Retrieve details of a specific subnet:
maas $PROFILE subnet read $SUBNET_ID
Toggle subnet management
UI
Subnets > (Select subnet) > Edit > Managed allocation > Save
CLI
- Enable management:
maas $PROFILE subnet update $SUBNET_CIDR managed=true
- Disable management:
maas $PROFILE subnet update $SUBNET_CIDR managed=false
Configure DNS servers per subnet
UI
Subnets > (Select subnet)j > Edit > DNS servers > Save
CLI
maas $PROFILE subnet update $SUBNET_CIDR dns_servers=$DNS_SERVER_IPS
Add static routes
UI
Subnets > (Select subnet) > Static routes > Add static route > Enter Gateway IP > Enter Destination subnet > Enter (optional) Metric > Save
CLI
Manage VLANs
Create VLAN
UI
Subnets > Add > VLAN > (Fill fields) > Add VLAN
CLI
maas $PROFILE vlans create $FABRIC_ID name=$VLAN_NAME vid=$VLAN_ID
Assign VLAN to interface
UI
Machines > (Select machine> > (Select physical interface) > Actions > Add VLAN
CLI
maas $PROFILE interfaces create-vlan $SYSTEM_ID vlan=$VLAN_ID parent=$INTERFACE_ID
Delete VLAN
UI
Subnets > (Select VLAN) > Delete VLAN > Delete VLAN*
CLI
maas $PROFILE vlan delete $FABRIC_ID $VLAN_ID
Manage IP addresses
Static IP via netplan
Modify /etc/netplan/50-cloud-init.yaml
network:
ethernets:
ens160:
addresses:
- 192.168.0.100/24
gateway4: 192.168.0.1
nameservers:
addresses:
- 8.8.8.8
- 8.8.4.4
Reserve IPs
Reserve a single IP
CLI
maas $PROFILE ipaddresses reserve ip=$IP_ADDRESS_STATIC_SINGLE
Reserve a dynamic range
UI
Subnets > (Select subnet> > (Scroll down> > Reserve range > Reserve dynamic range > (Fill fields) > Reserve
CLI
maas $PROFILE ipranges create type=dynamic subnet=$SUBNET_ADDRESS start_ip=$IP_DYNAMIC_RANGE_LOW end_ip=$IP_DYNAMIC_RANGE_HIGH
Reserve a static range
UI
Subnets > (Select subnet> > (Scroll down) > Reserve range > Reserve range > (Fill fields) Reserve
CLI
maas $PROFILE ipranges create type=reserved subnet=$SUBNET_ADDRESS start_ip=$IP_STATIC_RANGE_LOW end_ip=$IP_STATIC_RANGE_HIGH
Last updated a month ago.
