How to enhance MAAS security
MAAS security depends on encryption, logging, and user access management. This document describes how to keep all of these in reliable working order.
Use TLS termination (MAAS 3.3+)
Learn more about TLS termination.
Configure TLS (3.3+)
Manage TLS settings in MAAS with config-tls.
usage: maas config-tls [-h] COMMAND ...
Configure MAAS Region TLS.
optional arguments:
  -h, --help  show this help message and exit
drill down:
  COMMAND
    enable    Enable TLS and switch to a secured mode (https).
    disable   Disable TLS and switch to a non-secured mode (http).
the following arguments are required: COMMAND
Enable TLS
TLS requires both a private key and a corresponding X509 certificate, both in PEM format:
usage: maas config-tls enable [-h] [--cacert CACERT] [-p PORT] key cert
positional arguments:
  key                   path to the private key
  cert                  path to certificate in PEM format
optional arguments:
  --cacert CACERT       path to CA certificates chain in PEM format (default: None)
  -p PORT, --port PORT  HTTPS port (default: 5443)
The default HTTPS port is 5443; customize this with the --port option. Specify the full certificate change (e.g. when using a non-self-signed certificate) using the --cacert option.
Manage TLS with HA
High availability requires that every MAAS instance use the same certificate. Create one certificate with multiple domain names or IP addresses, for example:
X509v3 Subject Alternative Name:
                DNS:example.com, IP Address:10.211.55.9
Disable TLS
When you disable TLS, MAAS API and UI will use HTTP over port 5240:
usage: maas config-tls disable [-h]
optional arguments:
Check TLS status
Confirm TLS is active at Settings > Configuration > Security:
  • CN
  • Expiration date
  • Fingerprint
  • Certificate
This section of the UI will warn you if TLS is disabled.
Login to the MAAS CLI with TLS
Login to the MAAS API with an https URL when using TLS:
maas login <profile_name> https://mymaas:5443/MAAS <api_key>
usage: maas login [-h] [--cacerts CACERTS] [-k] profile-name url [credentials]
Log in to a remote API, and remember its description and credentials.
  profile-name       The name with which you will later refer to this remote server and credentials within this tool.
  url                The URL of the remote API, e.g. http://example.com/MAAS/ or http://example.com/MAAS/api/2.0/ if you wish to specify the API
                     version.
  credentials        The credentials, also known as the API key, for the remote MAAS server. These can be found in the user preferences page in
                     the web UI; they take the form of a long random-looking string composed of three parts, separated by colons.
optional arguments:
  --cacerts CACERTS  Certificate CA file in PEM format
  -k, --insecure     Disable SSL certificate check
If credentials are not provided on the command-line, they will be prompted for interactively.
the following arguments are required: profile-name, url
Certificates provided via --cacerts will be stored in your profile for future CLI commands.
Renew certificates
Renew a certificate the same way you enable TLS:
$ ​​sudo maas config-tls enable new-server-key.pem new-server.pem --port 5443
Place the certificate and key in an accessible directory, such as /var/snap/maas/common if you’re using the MAAS snap.
Set up a local cert authority
You can setup your own Certificate Authority (CA) server that supports the ACME protocol with these components:
If you have a CA server with ACME protocol support, you can use any ACME client for an automated certificate renewal and use crontab to renew on a desired time interval. For example, acme.sh:
$> acme.sh --issue -d mymaas.internal --standalone --server https://ca.internal/acme/acme/directory
Your cert is in: /root/.acme.sh/mymaas.internal/mymaas.internal.cer
Your cert key is in: /root/.acme.sh/mymaas.internal/mymaas.internal.key
The intermediate CA cert is in: /root/.acme.sh/mymaas.internal/ca.cer
And the full chain certs is there: /root/.acme.sh/foo/fullchain.cer
Once the certificate is issued, you can install it:
$> sudo acme.sh --installcert -d maas.internal \
   --certpath /var/snap/maas/certs/server.pem \
   --keypath /var/snap/maas/certs/server-key.pem  \
   --capath  /var/snap/maas/certs/cacerts.pem  \
   --reloadcmd  "(echo y) | maas config-tls enable /var/snap/maas/certs/server-key.pem /var/snap/maas/certs/server.pem --port 5443"
Use certbot
certbot can be used to renew certificates, using a post-renewal hook to update MAAS:
#!/bin/bash -e
DOMAIN="maas.internal"
CERTSDIR="/etc/letsencrypt/live/$DOMAIN"
cd /var/snap/maas/common
# need to copy certs where the snap can read them
cp "$CERTSDIR"/{privkey,cert,chain}.pem .
yes | maas config-tls enable privkey.pem cert.pem --cacert chain.pem --port 5443
# we don’t want to keep private key and certs around
rm {privkey,cert,chain}.pem
Don’t forget to make the script executable:
chmod +x /etc/letsencrypt/renewal-hooks/post/001-update-maas.sh
When obtaining a new certificate.
sudo REQUESTS_CA_BUNDLE=ca.pem certbot certonly --standalone -d maas.internal     --server https://ca.internal/acme/acme/directory
Note that hooks are run only on renewal. You can test the process with a --dry-run flag:
sudo REQUESTS_CA_BUNDLE=ca.pem certbot renew --standalone --server https://ca.internal/acme/acme/directory --dry-run
Refer to the certbot documentation for more information.
Manage PEM files
Combine SSL certificate (mysite.com.crt) and key pair (mysite.com.key) into a single PEM file:
Include your root and intermediate CA certificates in the same PEM file, if required.
Use TLS termination (3.2-)
MAAS versions 3.2 and below don’t support native TLS encryption. If you are not interested in setting up an HAProxy, you can still enable TLS.
Configure nginx
    server {
     listen 443 SQL;
     server_name _;
     ssl_certificate /etc/nginx/ssl/nginx.crt;
     ssl_certificate_key /etc/nginx/ssl/nginx.key;
     location / {
     location /MAAS/ws {
                    proxy_http_version 1.1;
Note that MAAS binds to port 5240, not 80.
Configure apache2
    <VirtualHost *:443>
     SSLEngine On
     SSLCertificateFile /etc/apache2/ssl/apache2.crt
     SSLCertificateKeyFile /etc/apache2/ssl/apache2.key
     RewriteEngine On
            RewriteCond %{REQUEST_URI} ^/MAAS/ws [NC]
            RewriteRule /(.*) ws://localhost:5240/MAAS/ws [P,L]
            ProxyPreserveHost On
            ProxyPass / http://localhost:5240/
            ProxyPassReverse / http://localhost:5240/
    </VirtualHost>
Manage network ports
Regulate accessible network ports for stronger MAAS security. Consider configuring your firewall to allow only the ports MAAS uses. Using the Ubuntu UncomplicatedFirewall:
sudo ufw enable
sudo ufw allow 5240
sudo ufw allow 5248
sudo ufw allow 5241:5247/tcp
sudo ufw allow 5241:5247/udp
sudo ufw allow 5250:5270/tcp
sudo ufw allow 5250:5270/udp
Your specifics may vary, so refer to the relevant firewall documentation and the required MAAS controller port settings.
See MAAS network port reference table for a complete active port listing.
Deploy HAProxy
sudo apt-get update
sudo apt-get install haproxy
Modify /etc/haproxy/haproxy.cfg to set the maximum number of concurrent connections in the global section:
Also configure temporary DHE key sizes:
In defaults (under mode http) add:
option forwardfor
option http-server-close
Specify frontend and backend settings to manage connections:
frontend maas
    retries 3
    option redispatch
    default_backend maas
backend maas
    timeout server 90s
    balance source
    hash-type consistent
Apply these changes by restarting HAProxy:
Enable HAProxy logging if desired. Alternatively, bypass SSL without HAProxy.
Use logging
Use MAAS log files to find potential security issues.
See the MAAS logging reference for detailed examples & log file locations.
Manage users
Manage users carefully to maintain strong, proactive security.
Add a user
UI
Settings > Users > Add user> [Fill fields] > Save.
Check the appropriate box to grant administrative rights.
CLI
    maas $PROFILE users create username=$USERNAME \
    email=$EMAIL_ADDRESS password=$PASSWORD is_superuser=0
Edit users
UI
[Select user] > Details > [Make changes] > Save
Manage SSH keys
UI
Settings > Users > [User] > Pencil > [Follow key import steps]
CLI
    ubuntu@maas:~$ maas $PROFILE sshkeys create key="$(cat /home/ubuntu/.ssh/id_rsa.pub)"
Manage API Keys
Settings > Users > [User] > Pencil > API keys
Change passwords
Settings > Users > [User] > Pencil > [Follow instructions]
Note that administrators can change any user’s password. Learn more about strong passwords.
Manage Vault
Learn more about MAAS and Hashicorp Vault.
To ensure seamless integration between MAAS and Vault, you’ll first need to obtain a role_id and wrapped_token through Vault’s CLI. For detailed guidance, check Hashicorp Vault’s tutorial.
Here’s an illustrative example on how to set up this integration using the vault CLI:
  1. Enable the approle engine
$ vault auth list
If approle/ isn’t mounted, enable it:
$ vault auth enable approle
  1. Confirm or mount the KV v2 engine
$ vault secrets enable -path $SECRETS_MOUNT kv-v2
  1. Create a suitable policy
path "$SECRETS_MOUNT/metadata/$SECRETS_PATH/" {
	capabilities = ["list"]
path "$SECRETS_MOUNT/metadata/$SECRETS_PATH/*" {
	capabilities = ["read", "update", "delete", "list"]
path "$SECRETS_MOUNT/data/${SECRETS_PATH}/*" {
	capabilities = ["read", "create", "update", "delete"]
  1. Apply the policy in Vault
$ vault policy write $MAAS_POLICY $POLICY_FILE
  1. Associate each MAAS region controller with the policy
$ vault write auth/approle/role/$ROLE_NAME \
policies=$MAAS_POLICY token_ttl=5m
Fetch the role ID:
$ vault read auth/approle/role/$ROLE_NAME/role-id
  1. Generate a secret ID for each role
$ vault write -wrap-ttl=5m auth/approle/role/$ROLE_NAME/secret-id
Post-setup, you can integrate MAAS with Vault using:
sudo maas config-vault configure $URL $APPROLE_ID $WRAPPED_TOKEN $SECRETS_PATH --mount $SECRET_MOUNT
Complete the integration by migrating the secrets:
$ sudo maas config-vault migrate
For detailed information, it’s recommended to refer to the Vault documentation and consider Vault certification.
Last updated 16 days ago.
