How to work with annotations
Work with annotations
This section explains how to work with notes, also known as “static annotations”. MAAS 2.9 does not support dynamic annotations; these are only supported from MAAS version 3.0.
How to work with static annotations
- How to create and assign static annotations
- How to delete static annotations
- How to view static annotations
- How to work with with dynamic (workload) annotations
To create and assign static annotations (a note) to a machine, follow this procedure:
- Go to the machine list and click on the machine of interest:
- This will bring up a machine summary for that machine:
- Select “Configuration” and click the “Edit” button to the right of the “Machine configuration” section:
Add free-form notes in the “Note” field, as desired.
Click “Save changes” to update the machine’s configuration.
To delete static annotations (a note) from a machine, follow this procedure:
Edit the free-form notes in the “Note” field, as desired.
To view static annotations, you can follow this procedure:
- Go to the machine list and look at the machine of interest; you should see the first few characters of a note in the bottom half of the column marked “POOL/NOTE:”
- Click on the machine, which will bring up a machine summary for that machine. Switch to the configuration tab to see the full note:
How to work with dynamic (workload) annotations
- How to view dynamic (workload) annotations for one machine
- How to filter on dynamic (workload) annotations
To view the dynamic (workload) annotations for one machine, do the following:
Go to the machine list and select the machine of interest by clicking on its hyperlinked name.
In the machine summary that comes up, look for the “Workload Annotations” card, in the lower, right-hand corner:
To filter machines by dynamic (workload) annotations, use the following procedure:
- Go to the machine list and select the “Filter” drop-down; open the “Workload” segment:
- Select one or more values from this list to filter the machine list by these workload annotations.
- How to identify your machines
- How to set a static annotation for a machine
- How to change or clear a static annotation for a machine
- How to list static annotations for all machines
- How to view a static annotation for one machine
maas $PROFILE machines read \
|@tsv' | column -t
For example:
maas admin machines read \
|@tsv' | column -t
hostname system_id
divine-stork 8b3ypp
casual-prawn 4end6r
driven-teal tgaat6
immune-beetle 43xand
good-osprey napfxk
smart-hen c4rwq7
boss-satyr xn8taa
golden-martin 8fxery
crack-guinea qk4b3g
finer-leech cy3dtr
free-mouse gxtbq4
humble-bunny srqnnb
wanted-muskox ekw7fh
one-boa by477d
great-urchin srnx4g
ace-frog g6arwg
alive-marlin gbwnfb
picked-parrot am77wn
tough-kit ke3wc7
legal-whale 8nq3mt
game-sponge 76pdc6
fun-ghoul qxfm7k
aware-earwig 8m8hs7
chief-crane 7fapx7
select-tapir 4ascbr
on-slug snfs8d
polite-llama dbqd4m
frank-coyote wcmk48
usable-condor ed8hmy
still-imp h6ra6d
For example:
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id description
driven-teal tgaat6 tango-golf
humble-bunny srqnnb sierra-romeo
tough-kit ke3wc7 kilo-echo
|@tsv' | column -t
For example:
|@tsv' | column -t
This section will help you learn:
- How to identify machines that can receive dynamic annotations
- How to set dynamic annotations for a machine
- How to clear and change dynamic annotations for a machine
- How to list dynamic annotations for all machines
- How to list dynamic annotations for one machine
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id status
divine-stork 8b3ypp Deployed
casual-prawn 4end6r Ready
driven-teal tgaat6 Allocated
immune-beetle 43xand Allocated
good-osprey napfxk Allocated
smart-hen c4rwq7 Allocated
boss-satyr xn8taa Ready
golden-martin 8fxery Allocated
crack-guinea qk4b3g Allocated
finer-leech cy3dtr Deployed
free-mouse gxtbq4 Allocated
humble-bunny srqnnb Allocated
wanted-muskox ekw7fh Deployed
one-boa by477d Allocated
great-urchin srnx4g Allocated
ace-frog g6arwg Ready
alive-marlin gbwnfb Deployed
picked-parrot am77wn Allocated
tough-kit ke3wc7 Deployed
legal-whale 8nq3mt Allocated
game-sponge 76pdc6 Allocated
fun-ghoul qxfm7k Allocated
aware-earwig 8m8hs7 Deployed
chief-crane 7fapx7 Ready
select-tapir 4ascbr Allocated
on-slug snfs8d Allocated
polite-llama dbqd4m Allocated
frank-coyote wcmk48 Allocated
usable-condor ed8hmy Deployed
still-imp h6ra6d Allocated
Dynamic annotations, otherwise known as “workload annotations” or “owner data,” can be used to keep track of the runtime status of machines that are allocated or deployed. These annotations are set using key=value
pairs. You can set any key=value
pair that you wish for any machine, although it’s probably more useful if you standardise your key names.
For example:
You can change dynamic annotations for a machine simply by executing a new set-owner-data
command:
You can clear a dynamic annotation by entering the empty string (""
) as the $VALUE:
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id owner_data
divine-stork 8b3ypp
casual-prawn 4end6r
driven-teal tgaat6 farquar foobar
good-osprey napfxk
smart-hen c4rwq7
|@tsv' | column -t
For example:
|@tsv' | column -t
Last updated 18 days ago.
