Configure several aspects of MAAS:
- MAAS behavior settings
- Rack controller port settings
- Interface parameters
Change MAAS settings and behavior to suit your environment. For the CLI, prefix the listed commands with:
maas $PROFILE maas set-config ...
Check the special commands at the bottom of the table, also
Setting | Description | UI Settings > | CLI | Example/Notes |
MAAS Name | Assign a unique name and emoji to identify your MAAS instance. | Configuration > General | maas_name | US-west-2 🇺🇸 MAAS-prod |
Theme Main Colour | Set a custom theme colour for the MAAS interface. | Configuration > General | Helps differentiate instances visually. | |
Data Analytics | Enable analytics to improve user experience. | Configuration > General | enable_analytics | Uses Google Analytics, Usabilla, and Sentry. |
Notifications | Enable notifications for new releases. | Configuration > General | release_notifications | Helps keep you informed of updates. |
Default Ubuntu Release for Commissioning | Set the default Ubuntu version for new machine commissioning. | Configuration > Commissioning | commissioning_distro_series | Default: Ubuntu 20.04 LTS. |
Default Minimum Kernel Version | Set the lowest allowed kernel version for new nodes. | Configuration > Commissioning | default_min_hwe_kernel | No minimum by default. |
Default OS for Deployment | Set the default operating system for deployments. | Configuration > Deploy | default_osystem | Example: Ubuntu, CentOS. |
Default OS Release for Deployment | Set the specific OS release for deployments. | Configuration > Deploy | default_distro_series | Example: Ubuntu 22.04, CentOS 7. |
Hardware Sync Interval | Frequency of hardware info syncs (in minutes). | Configuration > Deploy | hardware_sync_interval | Default: 15 minutes. |
Global Kernel Parameters | Set boot parameters for all machines. | Configuration > Kernel parameters | kernel_opts | Apply settings consistently during boot. |
Session Timeout | Set how long user sessions remain active. | Security > Session timeout | session_length | Max: 14 days. Example: “2 weeks” or “336 hours.” |
IPMI Settings | Configure IPMI username, key, and privilege level. | Security > IPMI settings | maas_auto_ipmi_… | Privilege levels: Admin, Operator, User. |
User Management | Manage users, including adding, editing, and deleting users. | Users | Search and sort users easily. | |
Proprietary Drivers | Enable proprietary drivers (e.g., HPVSA). | Images > Ubuntu | enable_third_party_drivers | Needed for certain hardware setups. |
Windows KMS Host | Set the host for Windows KMS activation. | Images > Windows | windows_kms_host | Enter FQDN or IP of the KMS host. |
VMware vCenter Server | Configure VMware vCenter settings (FQDN, username, datacenter). | Images > VMware | vcenter_… | Required for VMware ESXi deployments. |
License Keys | Add and manage product license keys. | License keys | Sortable, searchable table for licenses. | |
Default Storage Layout | Set the storage layout applied during commissioning. | Storage | default_storage_layout | Options: Bcache, Flat, LVM, etc. |
Disk Erasure Options | Choose secure or quick disk erasure methods. | Storage | disk_erase_with_… | Secure erase for supported devices. |
HTTP Proxy | Configure proxy for image downloads and package access. | Network > Proxy | http_proxy | Options: No proxy, Built-in, External, Peer. |
Upstream DNS | Set DNS servers for resolving external domains. | Network > DNS | upstream_DNS | Example: 8.8.8.8 for Google DNS. |
NTP Server | Configure NTP servers for time sync. | Network > NTP | ntp_servers | Use external NTP servers only if needed. |
Remote Syslog Server | Forward logs to a remote syslog server. | Network > Syslog | remote_syslog | Helps centralize logging. |
Network Discovery | Enable passive or active network discovery. | Network > Network discovery | network_discovery | Keeps discovery info accurate. |
Commissioning Scripts | Upload and manage commissioning scripts. | Scripts > Commissioning scripts | Scripts run during hardware setup. | |
Testing Scripts | Upload and manage testing scripts. | Scripts > Testing scripts | Scripts run to test hardware. | |
DHCP Snippets | Manage DHCP configuration snippets. | DHCP snippets | Useful for custom DHCP settings. | |
Package Repos | Add and manage APT/YUM repositories. | Package repos | Add PPAs or custom repos. |
Special commands
To enable TLS for secure communication:
sudo maas config-tls enable $key $cert --port YYYY
To enable Vault for secure secrets management:
sudo maas config-vault configure ...
Controller port settings
Essential TCP ports for MAAS communication:
Port(s) | Description |
5240 |
HTTP traffic with each region controller. In HA environments, port 80 is commonly used. |
5241 - 5247 |
Allocated for MAAS internal services. |
5248 |
Designated for rack HTTP communication. |
5250 - 5270 |
Reserved for region workers (RPC). |
5271 - 5274 |
Required for communication between Rack Controller (specifically maas-agent) and Region Controller |
5281 - 5284 |
Region Controller Temporal cluster membership gossip communication |
The following tables may be needed to manage MAAS interfaces.
Bond interface parameters
Parameter | Description | Req’d? | Allowable values |
name |
I/F name | Yes | String data |
mac_address |
MAC address of the I/F | No | String data |
tags |
Tags to apply to the I/F | No | String data |
vlan |
VLAN connected to I/F | No | String data |
parents |
Bonded I/F IDs | Yes | Integers |
bond-mode |
Operating mode of the bond | No | See table below |
bond_miimon |
Link monitoring freq in ms | No | Integer |
bond_downdelay |
Slave timeout in ms | No | Integer |
bond-updelay |
Reset recovery delay in ms | No | Integer |
bond_lacp-rate |
LACPDU 802.3ad rate | No | “Fast”/“Slow” |
bond_xmit_hash_policy |
Slave selection hash policy | No | String |
bond_num_grat_arp |
Peer failover ping count | No | Integer |
mtu |
Max transmission unit size | No | Integer |
accept_ra |
Accept router adverts | No | Boolean |
See Bond two interfaces for instructions on how to use and apply these parameters.
Physical interface parameters
key | value | format | type |
name | name of the interface | string | optional |
mac_address | MAC address of interface | string | required |
tags | tags | string | optional |
vlan | connected, untagged VLAN | string | optional |
mtu | max transmission unit | integer | optional |
accept_ra | accept router adverts | boolean | optional |
Note that if no VLAN is specified, the interface is considered disconnected.
VLAN interface parameters
vlan | connected, untagged VLAN | string | required |
parent | parent interface ID | string | required |
Interface-subnet link parameters
key | value | format | type | mode |
mode | See table below | string | required | ---- |
subnet | the linked subnet | integer | required | any |
ip_address | IP addr for interface | string | optional | STATIC |
force | force up, any VLAN | boolean | optional | LINK_UP |
default_gateway | subnet gateway IP | string | optional | AUTO |
^^ | STATIC |
Interface-subnet link modes
mode | description |
AUTO | Assign this interface a static IP address from the provided subnet. The subnet must be a managed subnet. The IP address will not be assigned until the node goes to be deployed. |
DHCP | Bring this interface up with DHCP on the given subnet. Only one subnet can be set to DHCP . If the subnet is managed this interface will pull from the dynamic IP range. |
STATIC | Bring this interface up with a static IP address on the given subnet. Any number of static links can exist on an interface. |
LINK_UP | Bring this interface up only on the given subnet. No IP address will be assigned to this interface. The interface cannot have any current AUTO , DHCP or STATIC links. |
Last updated 3 months ago.
