Setting up power drivers
To manage a machine, MAAS must be able to power cycle it, usually through the machine’s BMC^ card. Until you configure the power type, a newly-added machine can’t be enlisted and used by MAAS.
Configuring cipher suites in MAAS v3.2 and above
Cipher suite selection is a manual task because different BMCs have varying orders, causing incorrect discovery. You can specify the cipher suite to use with a BMC during power configuration. The default suite is 3, known for its low security. It’s your responsibility to choose a more secure suite if needed and supported.
Preferring Redfish over IPMI in MAAS 3.2
Redfish serves as an alternative to IPMI for interfacing with BMCs. Offering extended features compared to IPMA, Redfish is poised to replace it as the default.
MAAS 3.2 improved Redfish support, prioritising it over IPMI when:
  • The BMC has an active Redfish Host Interface
  • The MAAS host can access that interface
With version 3.2, MAAS brings auto-detection and preference for Redfish when enabled and available.
Unregistered machines on the MAAS PXE network can be manually booted. They enter an ephemeral environment to collect machine data. A script in this environment registers the machine in MAAS. As of v3.2, Redfish and IPMI are both supported for these BMC connections. MAAS can now automatically detect and configure either, given that a Redfish Host Interface is enabled and exposed.
Verifying Redfish activation
You can check if a machine communicates via Redfish with the command:
dmidecode -t 42
Additionally, you can review the 30-maas-01-bmc-config commissioning script’s output if the machine is already enlisted in MAAS.
Cipher suite management in MAAS v3.1 and earlier
In these versions, MAAS aims to automatically identify the most secure cipher suite. The preference hierarchy is 17, 3, 8, 12. Should auto-detection fail, MAAS reverts to freeipmi-tool’s default setting, suite 3.
Power management reference guide
In addition, this article provides a complete catalogue of power parameters, by type.
You may also like to try maaspower^ which is a community project designed to be used with the MAAS webhook driver. It is a pluggable system that accepts MAAS webhooks and can translate them to other external systems. Note: it is not supported by Canonical.
How to configure a machine’s power type via the UI
CLI power_type code Description
amt Intel AMT
apc American Power Conversion (APC) PDU
dli Digital Loggers, Inc. PDU
hmc IBM Hardware Management Console (HMC)
lxd LXD VM
ipmi IPMI
manual Manual power configuration
moonshot HP Moonshot - iLO4 (IPMI)
mscm HP Moonshot - iLO Chassis Manager
msftocs Microsoft OCS - Chassis Manager
nova OpenStack Nova
openbmc OpenBMC Power Driver
proxmox ProxMox Power Driver
recs_box Christmann RECS-Box Power Driver
redfish Redfish
sm15k SeaMicro 15000
ucsm Cisco UCS Manager
virsh libvirt KVM
vmware VMware
webhook Webhook
wedge Facebook’s Wedge
Power catalogue
Intel AMT
Form field Description Required
Power password Password to access unit Optional
Power address IP address of unit Required
IP for APC PDU IP address of unit Required
APU PDU node outlet number (1-16) PDU node outlet number Required
Power ON outlet delay (seconds) outlet power ON delay Optional, default=5
Outlet ID outlet ID Required
Power user Username to login Optional
IP for HMC IP address of unit Required
HMC username Username to login Optional
HMC password Password to access unit Optional
HMC Managed System server name HMC managed server name Required
HMC logical partition HMC logical partition of unit Required
LXD VMs
LXD address IP address of unit Required
Instance name LXD container instance name Required
LXD password Password to access unit Optional
IPMI
Form field Description Choices Required
Power driver Power driver LAN [IPMI 1.5] Required
LAN_2_0 [IPMI 2.0]
Power boot type Boot type Automatic Required
Legacy boot
EFI boot
IP address IP address of unit Required
Power MAC MAC address of unit Optional
K_g K_g BMC key Optional
Cipher suite Cipher suite ID - 17 (17 - HMAC-SHA256::HMAC_SHA256_128::AES-CBC-128) Optional
3 (3 - HMAC-SHA1::HMAC-SHA1-96::AES-CBC-128)
(blank) (freeipmi-tools default)
8 (8 - HMAC-MD5::HMAC-MD5-128::AES-CBC-128)
12 (12 - HMAC-MD5::MD5-128::AES-CBC-128)
Privilege level IPMI privilege level User Optional
Operator
Administrator
Power hardware address Hardware address of unit Required
IP for MSCM CLI API IP address of unit Required
MSCM CLI API user Username to login Optional
MSCM CLI API password Password to access unit Optional
Node ID cXnY Required
- where X = cartridge number
Y = node number
Power port Port where unit is attached Optional
Blade ID Blade ID (usu. 1-24) Required
OpenStack Nova
Host UUID Host UUID Required
Tenant name Tenant name Required
Username Username to login Required
Password Password to access unit Required
Auth URL URL to access unit Required
Proxmox
Power type Proxmox Required
Host name or IP Power address for the Proxmox driver Required
Username, including realm Power user, along with realm (i.e., Username@Realm Required
Password Required if a token name and secret aren’t given Provisional
API token name Token name: must include Username without realm (i.e., Username!Token-name Provisional
API token secret Token secret Provisional
Node ID VM name or ID Optional
Verify SSL connections… Boolean, whether or not to verify SSL connections with the system’s root CA certificate Required
OpenBMC address IP address of unit Required
OpenBMC user Username to login Required
OpenBMC password Password to access unit Required
Node ID Node ID Required
Redfish
Redfish address IP address of unit Required
Redfish user Username to login Required
Redfish password Password to access unit Required
Node ID Node ID Optional
SeaMicro 15000
System ID System ID Required
Power control type Password to access unit IPMI Required
REST API v0.9
REST API v2.0
Cisco UCS Manager
Server UUID Server UUID Required
URL for XML API XML API URL Required
API user API user Optional
API password API password Optional
virsh - libvirt KVM
Address URL of VM Required
Password API password Optional
Virsh VM ID libvirt VM UUID Required
VMware
VM Name VM name (if UUID unknown) Optional
VM UUID VM UUID (if known) Optional
VMware IP IP address of VM Required
VMware username Username to access VM Required
VMware password Password to access VM Required
VMware API port VMware API port number Optional
VMware API protocol VMware API protocol Optional
Facebook’s Wedge
Power user Username to access unit Optional
How to use the virsh power type
Pro tip: The machine’s hostname – according to MAAS – is a randomly chosen string (here dear.ant). You should change this hostname to something descriptive, that helps you remember why this machine is in your MAAS network.
Webhook
It’s important to understand that the Webhook power driver is more generic than other drivers, so it has some flexibility that the underlying power driver may not support. For example, Webhook doesn’t require a username or password for the power driver, because not all power drivers work that way. Nevertheless, the power driver you’re connecting to Webhook may actually require a username and/or password. Understanding and implementing these fields correctly for the chosen back-end power driver is the user’s responsibility.
To that end, the “Required” column for this driver refers only to whether Webhook requires a value in each field. Just because a field is optional for Webhook itself does not mean that the underlying power driver will ultimately allow that field to be unspecified.
Form field Description Required (by Webhook)
Power type Webhook (from drop-down list) Required
URI to power on the node URI to access power driver’s API for power on Required
URI to power off the node URI to access power driver’s API for power off Required
URI to query the nodes power status URI to access power driver’s API for power status Required
Regex to confirm the node is on Regex expression that will return a string if the power is on, and no string if the power is off Required, defaults supplied
Regex to confirm the node is off Regex expression that will return a string if the power is off, and no string if the power is on Required, defaults supplied
Power user Username to log into the power driver Optional
Power token Power driver API token (used instead of user and password, if set) Optional
How to configure a machine’s power type with the CLI
To (re)configure a machine’s power type, first find the machine’s $SYSTEM_ID with the following recipe:
maas admin machines read | jq -r '(["HOSTNAME","SIS'S"] | (., map(length*"-"))),
Next, use the MAAS CLI command maas machines... to (re)set the machine’s power type, like this:
maas $PROFILE machine update $SYSTEM_ID power_type="$POWER_TYPE"
where $POWER_TYPE can have the following values:
amt Intel AMT
eaton Eaton PDU
lxd LXD VM
ipmi IPMI
nova OpenStack Nova
redfish Redfish
virsh libvirt KVM
vmware VMware
Note the required and optional parameters associated with each power type.
Once you’ve successfully processed the command (as indicated by a stream of JSON, headed by “Success!”), MAAS performs a power check on the machine. A successful power check is a good indication that MAAS can properly communicate with the machine, that is, it should quickly result in a power status of “Power off”. A failed attempt will return errors that should guide you to fix your power_parameters.
Power catalogue
Intel AMT
All parameters are entered as key=value, e.g., power_type=amt. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
Parameter Description Required
power_type amt Required
power_address IP address of unit Required
power_pass Password to access unit Optional
All parameters are entered as key=value, e.g., power_type=apc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type apc Required
node_outlet PDU node outlet number Required
power_on_delay outlet power ON delay Optional, default=5
All parameters are entered as key=value, e.g., power_type=dli. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type dli Required
outlet_id outlet ID Required
power_user Username to login Optional
Eaton PDU
All parameters are entered as key=value, e.g., power_type=eaton. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type eaton Required
All parameters are entered as key=value, e.g., power_type=hmc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type hmc Required
server_name HMC managed server name Required
lpar HMC logical partition of unit Required
LXD VMs
All parameters are entered as key=value, e.g., power_type=lxd. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type lxd Required
instance_name LXD container instance name Required
IPMI
All parameters are entered as key=value, e.g., power_type=amt. The MAAS CLI will refuse the request with informative errors if required parameters are excluded. Power driver specific parameters should be prefixed with power_parameters_{key}.
power_driver Power driver LAN [IPMI 1.5] Required
LAN_2_0 [IPMI 2.0]
power_boot_type Boot type Automatic Required
Legacy boot
EFI boot
mac_address MAC address of unit Optional
k_g K_g BMC key Optional
cipher_suite_id Cipher suite ID 17 (17 - HMAC-SHA256::HMAC_SHA256_128::AES-CBC-128) Optional
privilege_level IPMI privilege level User Optional
Operator
Administrator
Manual power configuration means exactly that – manually configured at the unit. The only MAAS CLI parameter is power_type=amt.
All parameters are entered as key=value, e.g., power_type=moonshot. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | moonshot` Required
power_hwaddress Hardware address of unit Required
All parameters are entered as key=value, e.g., power_type=mscm. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | mscm` Required
node_id cXnY Required
Y = node number
All parameters are entered as key=value, e.g., power_type=msftocs. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | msftocs` Required
blade_id Blade ID (usu. 1-24) Required
power_port Port where unit is attached Optional
OpenStack Nova
All parameters are entered as key=value, e.g., power_type=nova. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | nova` Required
nova_id Host UUID Required
os_tenantname Tenant name Required
os_username Username to login Required
os_password Password to access unit Required
os_authurl URL to access unit Required
All parameters are entered as key=value, e.g., power_type=openbmc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type openbmc Required
power_user Username to login Required
power_pass Password to access unit Required
All parameters are entered as key=value, e.g., power_type=recs_box. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | recs_box` Required
node_id Node ID Required
Redfish
All parameters are entered as key=value, e.g., power_type=redfish. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | redfish` Required
node_id Node ID Optional
SeaMicro 15000
All parameters are entered as key=value, e.g., power_type=sm15k. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
Parameter Description Choices Required
power_type sm15k Required
system_id System ID Required
power_control Password to access unit ipmi Required
restapi
restapi2
Cisco UCS Manager
All parameters are entered as key=value, e.g., power_type=ucsm. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type ucsm Required
uuid Server UUID Required
power_address URL for XML API Required
power_user API user Optional
power_pass API password Optional
virsh - libvirt KVM
All parameters are entered as key=value, e.g., power_type=virsh. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type virsh Required
power_id libvirt VM UUID Required
power_address URL of VM Required
VMware
All parameters are entered as key=value, e.g., power_type=vmware. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type vmware Required
power_vm_name VM name (if UUID unknown) Optional
power_uuid VM UUID (if known) Optional
power_address IP address of VM Required
power_user Username to access VM Required
power_pass Password to access VM Required
power_port VMware API port number Optional
power_protocol VMware API protocol Optional
Facebook’s Wedge
power_type wedge Required
power_user Username to access unit Optional
Consider a machine backed by a KVM, accessed via virsh. You can create a corresponding MAAS machine and set its power parameters with a command like this one:
maas admin machines create \
architecture=amd64 \
power_type=virsh \
power_parameters_power_id=f677a842-571c-4e65-adc9-11e2cf92d363 \
If successful, this will return:
Machine-readable output follows this announcement. The JSON generated by this command is shown in the detail block.
MAAS command JSON response ``` { "storage": 0.0, "tag_names": [], "special_filesystems": [], "memory": 0, "boot_disk": null, "virtualblockdevice_set": [], "hardware_info": { "system_vendor": "Unknown", "system_product": "Unknown", "system_family": "Unknown", "system_version": "Unknown", "system_sku": "Unknown", "system_serial": "Unknown", "cpu_model": "Unknown", "mainboard_vendor": "Unknown", "mainboard_product": "Unknown", "mainboard_serial": "Unknown", "mainboard_version": "Unknown", "mainboard_firmware_vendor": "Unknown", "mainboard_firmware_date": "Unknown", "mainboard_firmware_version": "Unknown", "chassis_vendor": "Unknown", "chassis_type": "Unknown", "chassis_serial": "Unknown", "chassis_version": "Unknown" }, "address_ttl": null, "memory_test_status": -1, "other_test_status_name": "Unknown", "osystem": ", "status_message": "Commissioning", "netboot": true, "physicalblockdevice_set": [], "node_type": 0, "cpu_test_status": -1, "memory_test_status_name": "Unknown", "bcaches": [], "storage_test_status": 0, "system_id": "bhxws3", "status": 1, "commissioning_status": 0, "power_type": "virsh", "locked": false, "numanode_set": [ { "index": 0, "memory": 0, "cores": [] } ], "bios_boot_method": null, "fqdn": "ace-swan.maas", "node_type_name": "Machine", "hostname": "ace-swan", "volume_groups": [], "testing_status": 0, "network_test_status": -1, "other_test_status": -1, "interface_test_status": -1, "hwe_kernel": null, "blockdevice_set": [], "testing_status_name": "Pending", "power_state": "unknown", "min_hwe_kernel": ", "owner": "admin", "distro_series": ", "storage_test_status_name": "Pending", "cpu_speed": 0, "swap_size": null, "cpu_test_status_name": "Unknown", "hardware_uuid": null, "architecture": "amd64/generic", "pool": { "name": "default", "description": "Default pool", "id": 0, "resource_uri": "/MAAS/api/2.0/resourcepool/0/" }, "cache_sets": [], "pod": null, "iscsiblockdevice_set": [], "disable_ipv4": false, "status_action": ", "boot_interface": { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": ", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" }, "cpu_count": 0, "domain": { "authoritative": true, "ttl": null, "resource_record_count": 0, "name": "maas", "is_default": true, "id": 0, "resource_uri": "/MAAS/api/2.0/domains/0/" }, "current_testing_result_id": 7, "default_gateways": { "ipv4": { "gateway_ip": null, "link_id": null }, "ipv6": { "gateway_ip": null, "link_id": null } }, "interface_set": [ { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": ", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" } ], "status_name": "Commissioning", "commissioning_status_name": "Pending", "owner_data": {}, "ip_addresses": [], "raids": [], "network_test_status_name": "Unknown", "description": ", "current_commissioning_result_id": 6, "interface_test_status_name": "Unknown", "current_installation_result_id": null, "zone": { "name": "default", "description": ", "id": 1, "resource_uri": "/MAAS/api/2.0/zones/default/" }, "resource_uri": "/MAAS/api/2.0/machines/bhxws3/" } ```
[/tab]
[/tabs]
Which BMC drivers are supported
Tell me about BMC
Cisco UCS Manager X X X
Digital Loggers, Inc. - PDU
Facebook's Wedge *
IPMI X X X X
Intel AMT X X X
Manual
OpenStack Nova X
Rack Scale Design X X X
Redfish X X X
SeaMicro 15000 X X X
Sentry Switch CDU - PDU
VMWare X X X
Virsh (virtual systems) X X X
How to configure and use IBM Z with MAAS
MAAS 2.9 does not support IBM Z
The IBM Z or LinuxONE system can host MAAS controllers and is able to deploy predefined logical partitions (LPARs) KVM host(s), and virtual machines, if the mainframe is set up properly for MAAS.
The basic architecture is similar to this:
Networking would be structured like this:
Note that net-booting the KVM guests (through the two bridges) can be problematic. There are two options:
  1. Adding VNIC characteristics to enable “learning” on the network interface that’s the base for bridge “br2.” This is the recommended approach.
  2. Enable full promiscuous bridge port mode at the network interface that’s the base for bridge “br2.” This approach is not recommended because it has some built-in limitations.
MAAS will automatically configure option 1 for you, in case an LPAR is deployed as KVM host (the bridge names may differ).
In order to achieve this configuration, there are a number of steps that must be executed; specifically, you must know how to:
The MAAS controller does not necessarily need to run on an LPAR on the IBM Z system itself, but can also run on a different system outside. But since the MAAS controller requires a network connection to the hardware management console (HMC), it is recommended to keep it co-located and (for security reasons) as close as possible to the HMC and run it in a dedicated LPAR.
Such a MAAS controller LPAR should have at least two SMT hardware threads (one IFL), since it runs several services (bind, rack-, region-controller and more), 16 GB RAM and 100 GB disk space - recommended is to use the double amount of these resources.
The resources of the LPARs to deploy on (‘machines’ in terms of MAAS) depending on the use case. LPARs that are deployed as KVM host would of course require significantly more resources to be able to host KVM guest on top.
There are several constraints on the definition and setup of the ‘machine’ LPARs - please see below.
Evaluate IBM Z requirements
The system requirements to host MAAS and its virtual machines on the IBM Z platform are as follows:
  • IBM z14 GA2 (or newer) or IBM LinuxONE III (or newer)
  • HMC running in DPM mode (mandatory, traditional mode is not supported!)
  • HMC firmware level H39 - (HMC at H40 and SE at S55)
  • HMCs Rest-API enabled
  • python-zhmcclient (0.29 or later) running on the MAAS controller system, connected to the HMC
  • HMC user ID for the zhmcclient access to the HMC API (must have permissions for the “Manage Web Services API Logs” role and “Manage Web Services API Logs” role)
  • I/O auto-configuration enabled for the ‘machine’ LPARs
  • zFCP (SCSI) disk storage (only, no DASD support), recommended are two disks, one defined as type ‘boot,’ the second as type ‘data’
  • a dedicated storage group per ‘machine’ LPAR; these must include the dedicated zFCP storage for this particular managed LPAR only (‘boot’ and ‘data’ for LPAR n) - but no additional shared storage!
  • qeth network devices (Hipersockets or OSA, recommended); at least one qeth NIC, recommended two (or more)
  • Ubuntu Server 20.04 installed on a dedicated system (LPAR or PC), that acts as MAAS Controller
  • one or more LPARs as ‘machines’ (aka MAAS deployment targets)
Be aware that these are minimum system requirements.
Access the HMC and login to the IBM Z
To login to the HMC, you must have at least “system programmer” privileges. Gaining that level of access is beyond the scope of this document. Once you are sure that you have the necessary access, you first need to navigate to the Hardware Management Console (HMC) application in your Web browser:
Click on the “Log on…” link, which will bring you to a login screen:
Upon successfully logging on, you will land on the Welcome Screen:
Select the “Tasks Index” on the left-hand navigation:
From here, you will be able to access the commands needed to prepare your IBM Z to host MAAS.
Set up a suitable IBM Z partition for a MAAS machine
In order to prevent MAAS from taking over the entire system, you must assign both the controller and the ‘machines’ / KVM hosts to specific partitions, with suitable limitations. To set up suitable IBM Z partitions for hosting MAAS, you must choose “Partition Details” from the “Tasks Index,” which will bring you to a screen like this one:
You must then choose the “target object” (in this case we’ve chosen TA05) to be operated upon:
Click “OK,” and you’ll arrive at a screen similar to the one below:
Make sure you’re on the “Partitions” tab, and select the desired object (“TA05…”):
Right-click on the selected object and select “Partition Details:”
On the “General” tab, edit the partition details to suit your proposed MAAS deployment:
Next, you will set up the networking details for this partition, as shown in the following section.
Set up IBM Z networking for a MAAS machine
To properly enable networking within the IBMZ partitions, you must change to the “Network” tab under “Partition Details:”
Click on the NIC of interest to bring up the “NIC Details” screen:
Confirm that the parameters on this screen are consistent with your planned MAAS deployment, then bring up the network adapter(either OSA or Hipersockets) by selecting it:
Ensure that all settings on the “General” tab conform to your planned MAAS deployment; then select the “Network Interface Cards” tab on the left-hand navigation:
Again, ensure that the parameters associated with the networking arrangement are consistent with your planned MAAS deployment.
Next, you will set up the storage layout for your MAAS partition(s).
Set up IBM Z storage for a MAAS machine
To set up suitable storage for a MAAS deployment, you should bring up the “Partition Details” for your chosen MAAS partition and select the “Storage” tab from the left-hand navigation:
Choose the “VOLUMES” sub-tab, and lick on the hyperlinked partition name to bring up the storage configuration tab:
Click on “GET DETAILS” for the Boot Volume in the Volume list to bring up the “Configuration details” screen:
Ensure that the Boot Volume is configured appropriately for your planned MAAS deployment, then click “Done.” Then return to the storage configuration tab and choose the Data Volume, and tune it to the appropriate parameters.
Next, choose the “ADAPTERS” sub-tab to bring up information on the storage adapters:
Set any necessary parameters to conform to your planned MAAS deployment.
Set the partition boot parameters
Return to the “Partition Details” screen and select the “Boot” tab in the left-hand navigation:
Change any settings as necessary to support your planned MAAS deployment.
Set up your IBM Z virtual machine for enlistment
To cause IBM Z KVM partition guests to enlist, it’s necessary to manually put in the BMC information for each guest. MAAS can then detect the guest, enlist it, and boot it as necessary.
Last updated a month ago.
