Machine groups allow you to categorize machines for easy recognition and bulk action.
Availability zones
Availability zones (AZs) in MAAS improve fault tolerance, service performance, and power management by organizing resources across physical or network areas. If there is failure in one AZ, you can quickly switch to another one.
Manage availability zones
Create, update and delete availability zones as desired.
Create an availability zone
UI
Main menu > AZs > Add AZ > Enter Name, Description > Add AZ.
CLI
maas $PROFILE zones create name=$ZONE_NAME description=$ZONE_DESCRIPTION
Update an availability zone
UI
Main menu > AZs > Select AZ > Edit > Update Name, Description > Update AZ.
CLI
maas $PROFILE zone update $OLD_ZONE_NAME name=$NEW_ZONE_NAME \
Delete an availability zone
UI
Main menu > AZs > Select zone > Delete AZ > Delete AZ.
CLI
maas $PROFILE zone delete $ZONE_NAME
List availability zones
UI
Main menu > AZs
CLI
maas $PROFILE zones read \
| jq -r '(["ZONE","NAME","DESCRIPTION"]
| (., map(length*"-"))), (.[] | [.id, .name, .description])
| @tsv' | column -t
Example output:
ZONE NAME DESCRIPTION
5 BizOffice
1 default
4 Inventory
2 Medications
3 Payroll
6 ProServ
Assign a machine to an availability zone
UI (MAAS 3.4)
Machines > Select machines > Categorise > Set zone > Choose Zone > Set zone for machine.
UI
Machines > Select machines > Take action > Set zone > Choose Zone > Set zone for machine.
CLI
maas admin machine update $SYSTEM_ID zone=$ZONE_NAME
Resource pools
MAAS uses resource pools to group machines and VM hosts for better allocation. New machines default to the “default” pool. Resource pools are useful when you are budgeting a limited number of machines across different datacenter functions
Manage resource pools
Create, update, delete and list resource pools as needed.
Create a resource pool
UI
- MAAS 3.4: Organisation > Pools > Add pool > Enter Name & Description > Save pool.
- Earlier versions: Resource > Add pool > Enter Name & Description > Add pool.
CLI
maas $PROFILE resource-pools create name=$NAME description="$DESCRIPTION"
Update a pool
CLI
description
is optional.
Delete a resource pool
UI
- MAAS 3.4: Organisation > Pools > (trash can) > Delete.
- Earlier versions: Resource > (trash can) > Delete.
CLI
List resource pools
CLI
View a single pool
CLI
Assign machines to pools
Attach or detach machines from a resource pool at any time.
Attach a machine to a pool
UI
- MAAS 3.4 forward: Machines > Select machine > Categorise > Set pool > Select Resource pool > Set pool.
- Earlier versions: Machines > Select machine > Configuration > Set Resource pool > Save changes.
CLI
Detach a machine from a pool
UI
- MAAS 3.4: Same as “Add a machine to a pool,” but select “default” as the resource pool.
- Earlier versions: Machines > (machine) > Configuration > Set pool to “default” > Save changes.
CLI
maas $PROFILE machine update $SYSTEM_ID pool="default"
Attach a VM host to a pool
UI
- MAAS 3.4: KVM > LXD > Select VM host > KVM host settings > Resource pool > Save changes.
- Earlier versions: Assign pool during VM host creation or edit VM host settings.
CLI
maas $PROFILE vm-host update $SYSTEM_ID pool=$POOL_NAME
Detach a VM host from a pool
UI
- MAAS 3.4: Same as “Add a VM host to a pool,” but select “default” as the resource pool.
- Earlier versions: Edit VM host settings and assign to “default”.
CLI
maas $PROFILE vm-host update $SYSTEM_ID pool="default"
Tags and annotations
MAAS also offers methods to label machines at all life-cycle stages, including tags, notes, and dynamic annotations. Tags are persistent labels that remain associated with machines until you remove them.
How to name a tag
- Tag names can include any combination of alphabetic letters (a-zA-Z), numbers (0-9), dashes (-) and underscores (_).
- Tag names can be a maximum of 256 characters in length.
- Tag names cannot include spaces.
Tagging machines
Manage machine tags on the fly, as they are created and attached to machines.
Add a tag
UI
Machines > (Select machine) > Take action > Tag > (Enter tag name) > Create tag > (Fill out form) > Create and add to tag changes > Save.
UI (Version 3.1 and older)
Enter the tag name in the Tags box > (Return) > (Select completion).
CLI
Add a kernel option tag
CLI (only)
Delete a tag from all machines
UI
Machines > Tags > (Trash can icon) > Delete
CLI
Delete a tag from specific machines
Machines > (Select machines) > Take action > Tag > Remove > Save.
Remove tags
With MAAS 3.1 and earlier versions, you remove tags, rather than explicitly deleting them. Tags are “deleted” when you have removed them from all machines.
UI
Tags box > (Select the X next to tag to remove) > (Select appropriate completion button)
Unassign tags
UI (only)
Machines > (Select machine) > Take action > Tag > Remove (on specific tag) Save
List tagged nodes
CLI (only)
GRUB_CMDLINE_LINUX_DEFAULT="sysrq_always_enabled dyndbg='file drivers/usb/* +p' console=tty1 console=ttyS0"
Update tags
CLI (only)
List all tags
CLI (only)
Rebuild a tag
CLI (only)
This command automatically applies the tag to all machines regardless of state, even machines that are actively deployed.
Manage automatic tags
MAAS 3.2 and above can auto-apply tags to machines based on XPath expressions.
Create automatic tags (MAAS 3.4 and above)
UI
Organisation > Tags > Create new tag > (Fill in form) > Save
Note: Adding and XPath expression makes a tag automatic.
Change tag definitions
UI
Organisation > Tags > (Pencil icon) > (Edit definition) > Save
MAAS will re-tag all matching machines in a background process.
Creating automatic tags (3.3/3.2)
Machines > Tags > Create new tag > (Fill in form) > Save
Update tag definitions
UI
Machines > Tags > (Pencil icon) > Edit the Definition > Save.
MAAS will re-tag all matching machines in the background.
Update tag kernel options
UI (only)
Machines > Tags > (Select pencil icon) > Kernel options > Save.
Kernel options can exist for both manual and automatic tags. However, they will be applied during boot time (commissioning and deploying). If the tagged machines are deployed, the updated kernel option won’t apply until the machines are redeployed. We suggest that you release those machines prior to the update, then redeploy those machines when the kernel options of the tag are updated.
Manage VM host tags
Apply tags to VM hosts to help distinguish them.
Assign tags to a VM host
**CLI (only)
maas $PROFILE vmhosts read \
| @tsv' | column -t
maas $PROFILE vmhost add-tag $VMHOST_ID tag=$TAG_NAME
Remove VM host tags
CLI (only)
### List VM host tags
**CLI (only)**
```nohighlight
View VM host tags (MAAS 3.4)
UI
KVM > (VM host type) > (VM host) > KVM host settings > Tags. You can also edit, add, or delete tags from this view.
View VM host tags (MAAS 3.3 and below)
UI
KVM > (VM host) > KVM host settings > Tags. You can also edit, add, or delete tags from this view.
View VM host tags (CLI)
CLI
| @tsv' | column -t
Annotations
Annotations add context and metadata to your machines for identification and filtering. There are two types: notes, which are static and survive throughout the life-cycle; and dynamic annotations, which only exist during deployment.
Note: Dynamic annotations aren’t supported in MAAS version 2.9 or earlier.
Manage notes
Notes are longer, persistent descriptions that stay with a machine throughout its life-cycle unless manually altered.
Add or modify notes
UI
Machines > (Machine) > Configuration > Edit > Note > (Edits) > Save changes.
CLI
maas $PROFILE machines read \
|@tsv' | column -t
maas $PROFILE machine update $SYSTEM_ID description="$NOTE"
To erase a note, just use an empty string.
Manage dynamic annotations
Dynamic annotations are ephemeral data attached to allocated or deployed machines.
Identify eligible machines
To list machines that can receive annotations, execute:
CLI (only)
|@tsv' | column -t
Set an annotation
Set annotations using key=value
pairs:
CLI (only)
Change an annotation
CLI (only)
Remove an annotation
CLI (only)
List annotations
CLI (only)
|@tsv' | column -t
Last updated 2 months ago.
