Using machine tags
Machine tags with UI, version 3.4
- How to create and assign machine tags to machines
- How to remove and delete machine tags from machines
- How to list machine tags for multiple machines
- How to view machine tags for one machine
- How to view machine tags for a VM host
If you want to create a new tag, and simultaneously assign it to one or more machines, use the following steps:
Select Machines.
Select the checkbox next to the machine(s) you want to tag.
Select Categorise >> Tag.
Create and/or assign the desired tag, as described in the general tagging procedure above.
Select Save to register your changes.
Select Machines.
Select the machine in question by clicking on its name.
Check the Tags pane under Machine summary to confirm the tags applied to the machine.
Select Edit.
Follow the general tag removal procedure.
In the MAAS UI, you don’t explicitly list all machine tags; instead, you filter by them using the “Filters” drop-down:
Select Machines.
Select the Filters drop-down.
Select Tags in the drop-down.
Select one or more tags by clicking on the tag name.
The machine list will automatically filter by (be limited to) the machines matching the selected tag(s).
Remove a tag from the search filter by either by deselecting it in the Tags section.
Select Machines.
Select the machine of interest by clicking on its name.
Select Configuration.
Scroll down to the Tags section.
Under KVM, select the type of VM host you’re investigating.
Select a VM host by clicking on its name.
Select KVM host settings.
You can view, edit, add, or delete tags in the Tags box.
Machine tags with UI, MAAS versions 3.3 and below
Select Machines.
Select Take action >> Tag.
Select Tag machine to register your changes.
Select Machines.
Select Configuration >> Edit.
To list all tags, visit the ‘Machines’ tab and expand the ‘Tags’ subsection in the left pane. In this view, you can use tags as machine search filters.
Select one or several tags. The machines that satisfy all selected tags will display on the right pane. Notice there is a search field at the top of the right pane. You can type a search expression into this field.
On the machine list, select the machine of interest by clicking on its name.
On the machine detail screen that comes up, look for the tags on one of the cards presented there: the tags for that machine should be listed there.
Select KVM.
Machine tags with the MAAS CLI, all versions
- How to assign machine tags to a machine
- How to remove machine tags from a machine
- How to list machine tags for all machines
- How to discover your virtual machine host ID
- How to assign tags to a virtual machine host
- How to remove tags from a virtual machine host
- How to list tags for all virtual machine hosts
- How to view tags for one virtual machine host
For example:
"added": 1,
"removed": 0
| @tsv' | column -t
hostname sysid machine_tags
divine-stork 8b3ypp pod-console-logging virtual
casual-prawn 4end6r pod-console-logging virtual
driven-teal tgaat6 pod-console-logging virtual
immune-beetle 43xand pod-console-logging virtual
good-osprey napfxk pod-console-logging virtual
smart-hen c4rwq7 pod-console-logging virtual
boss-satyr xn8taa pod-console-logging androko
golden-martin 8fxery pod-console-logging virtual
crack-guinea qk4b3g pod-console-logging virtual
finer-leech cy3dtr pod-console-logging virtual
free-mouse gxtbq4 pod-console-logging virtual
humble-bunny srqnnb pod-console-logging virtual
wanted-muskox ekw7fh pod-console-logging virtual
one-boa by477d pod-console-logging virtual
great-urchin srnx4g pod-console-logging virtual
ace-frog g6arwg pod-console-logging virtual barbar farquar new_tag
alive-marlin gbwnfb pod-console-logging virtual
picked-parrot am77wn pod-console-logging virtual
tough-kit ke3wc7 pod-console-logging virtual
legal-whale 8nq3mt pod-console-logging virtual
game-sponge 76pdc6 pod-console-logging virtual
fun-ghoul qxfm7k pod-console-logging virtual
aware-earwig 8m8hs7 pod-console-logging virtual
chief-crane 7fapx7 pod-console-logging virtual
select-tapir 4ascbr pod-console-logging virtual
on-slug snfs8d pod-console-logging virtual
polite-llama dbqd4m pod-console-logging virtual
frank-coyote wcmk48 pod-console-logging virtual
usable-condor ed8hmy pod-console-logging virtual
still-imp h6ra6d pod-console-logging virtual
For example:
"added": 0,
"removed": 1
Adding and removing machine tags simultaneously from multiple machines
"added": 2,
"removed": 1
| @tsv' | column -t
golden-martin 8fxery pod-console-logging virtual barbar
one-boa by477d pod-console-logging virtual barbar
ace-frog g6arwg pod-console-logging virtual farquar
For example:
| @tsv' | column -t
For example:
| @tsv' | column -t
maas $PROFILE vmhosts read \
| @tsv' | column -t
For example:
maas admin vmhosts read \
| @tsv' | column -t
vm_host_name id
my-lxd-vm-host-1 1
maas $PROFILE vmhost add-tag $VMHOST_ID tag=$TAG_NAME
If it worked, this should return Success
, followed by the JSON that describes the VM host. You can check your work by listing all VM host tags.
For example:
vm_host_name id tags
my-lxd-vm-host-1 1 morkopongo pod-console-logging virtual
| @tsv' | column -t
name id tags
Last updated a month ago.
