Using network tags
Maastering network interface tags
Get to grips with the nitty-gritty of network interface tags in MAAS. With these tabs, you’ll find the steps laid out for both UI and CLI users.
Network tags with the UI
Note: In the operations that follow, autocomplete might be scarce, as interface tags don’t usually carry over between machines with different MAC addresses.
Creating and tagging network interfaces
To slap a tag onto an interface:
  1. Navigate to Machines.
  2. Choose the machine linked to the target interface.
  3. Go to Network.
  4. Hit Edit physical on the row for your chosen interface.
  5. Look for the Tags field.
  6. Type in your new tag.
  7. Finalise by clicking Save interface.
Erasing tags
To remove a tag from an interface:
  3. Go to Network.
  6. Click the X next to the tag you want gone.
  7. Seal the deal by clicking Save interface.
Peering into tagland
To scrutinise the tags on an interface:
  3. Go to Network.
  5. Observe the Tags field.
  6. Click Cancel when done marvelling.
Network tags with the CLI
Discover your interface’s ID
Identify your network interfaces with a command akin to this:
|@tsv'| column -t
Example:
|@tsv'| column -t
Expect output like:
mac_address        type      id  tags
00:16:3e:18:7f:ee  physical  9   andrpko  plinko  cochise
Tag it up, CLI style
Tag your network interface with this command format:
Example:
You’ll see a verbose JSON output revealing the changes.
CLI tag deletion
To exterminate a tag:
Example:
You’ll be greeted with a JSON output that confirms the tag’s removal.
Tag census
List all tags with:
|@tsv'| column -t
Example:
|@tsv'| column -t
Expect output like:
00:16:3e:18:7f:ee  physical  9   andrpko  plinko  cochise  farquar
Single-interface tag viewing
To scope out tags on a specific interface:
| jq '.tags'
Example:
maas admin interface read xn8taa 9 | jq '.tags'
Anticipate a JSON output displaying the tags.
Last updated a month ago.
