Using storage tags
This article explains how to create, assign, remove, and view block device tags in MAAS. Block device tags are useful for organizing and categorizing your storage resources in MAAS. Here you will find:
Device tags with the CLI
- How to create and assign block device tags
- How to remove and delete block device tags
- How to list block device and partition tags
- How to view block device tags
- How to view partition tags
Remember: In order to create and assign tags to a block device, the device has to be in an “available” state, with no active partitions.
To create and assign tags to block devices:
Select Machines.
Select the machine that has the block device you want to tag.
Select Storage.
Scroll to Available disks and partitions.
Select the Edit… option at the right end of the row for the block device you want to tag (the wording may vary).
Add Tags as desired.
Register your changes by selecting Save.
Select Machines.
Select Storage.
Remove Tags by selecting the X on the tag name.
To see block device and partition tags in the UI, you can list all storage links by using the filter tool on the machine list. Here’s how:
Select Machines.
Select Filters >> Storage tags from the drop-down.
Select the tags you wish to filter against. The screen will immediately narrow to match your selections.
Uncheck tags to return to the previous view.
Select Machines.
Select the machine you want to examine.
Select Storage.
Scroll down to Available disks and partitions.
You can view the various storage tags in this table.
Select Machines.
Select Storage.
How to discover the ID of your block device
| @tsv' | column -t
For example:
| @tsv' | column -t
system_id block_device_id path avail_size
qk4b3g 10 /dev/disk/by-dname/sda 0
The path
component is printed to help you confirm that you are choosing the right block device when there are several present. The avail-size
column will tell you whether you can operate on that block device at all. If the available size is “0,” for example, you can’t set a block device tag on any part of that drive. Instead, you’d want to see something like this:
xn8taa 8 /dev/disk/by-dname/sda 1996488704
How to assign tags to a block device
For example:
If this command succeeds, it will display Success
, followed by a JSON sequence describing the new state of the block device.
Not Found
How to remove tags from a block device
For example:
Note that if you try to remove a tag from a block device that is not available, that is, from a block device that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the block device you’ve chosen, MAAS will simply return Success
, followed by a JSON sequence describing the current state of the block device.
How to list tags for all block devices
For example:
id tags
8 hello ssd trinkoplinko
How to view tags for one block device
For example:
id tags
9 20gig ssd
10 250Gs ssd
<a href="#heading–discover
-the-id-of-your-partition">
How to discover the ID of your partition
|@tsv' | column -t
For example:
|@tsv' | column -t
system_id block_dev_id part_id path
xn8taa 8 67 /dev/disk/by-dname/sda-part1
The path
component is printed to help you confirm that you are choosing the right partition, when there are several present.
How to assign tags to a partition
For example:
, followed by a JSON sequence describing the new state of the partition.
Not Found
How to remove tags from a partition
For example:
Note that if you try to remove a tag from a partition that is not available, that is, from a partition that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the partition you’ve chosen, MAAS will simply return Success
, followed by a JSON sequence describing the current state of the partition.
How to list tags for all partitions
| @tsv' | column -t
For example:
| @tsv' | column -t
id tags
54 farquar swap opendisk
67 foobar farquar
97 foobar
How to view tags for one partition
To view tags for one partition, enter
For example:
id tags
67 farquar foobar
Remember, these are the basic commands for managing tags on block devices and partitions. You can adapt them to your specific needs and use cases within your MAAS environment.
Last updated a month ago.
