General reference
The following general reference information is provided for MAAS users:
- Release notes: Comprehensive release notes that go back several versions, well beyond the support window.
- Concepts & terms: A massive glossary of technical terms, in case you should run into trouble with some vocabulary.
- Getting help: A guide to how to get help.
- How to report a bug: The minimum necessary information we need to work on reported bugs.
Last updated 30 days ago.
